Bad amp?
Wiktorrr
15
Montreal
looking for good help, please advise if you can. I wired my amp to my head unit using speaker level ins. It’s a 5 channel amp. I bridged it to power my front speakers. The right speaker and tweeter keep cutting in and out. To see if it was the amp I switched the outputs around and now my left speaker and tweeter cut in and out. Also the amp has signal sensing turn on/off but it just stayes on. It’s a bran new amp had it for a day, it starting doing that 10 minutes into using it. Any suggestions ?
Double Check if you bridged it correctly. Check wiring at terminals on speakers and amp.
Do you have another amp to test out to see if it cuts out the same way? Personally from experience this is the best way to rule out a lot of things when diagnosing this kinds of problems.
I triple checked my wiring, and It’s good. It seems like the problem is with channel A because when I unbridge and put both speakers on channel A (it’s a 5channel amp) they both cut off.
That's why I said it really depends on the sub 😂
Bonjour et bienvenue à mon ami d'outre-Atlantique! Need a lot more info on what the goal is and what you are working with. What car? Did it come...
Hello back, For those who are also looking for a problem of sh*t bass, after such a long time of fighting, I come to a conclusion that the...
17
4K
"large crimping tool" hammer or hydraulic? Seat bracket bolts aren't good. The seat brackets are usually completely painted and so are the...
All that carpet will have to be ripped out and replaced. There is no other way around it to get it done properly. Seal both sides of the...
17
Wiktorrr
Wiktorrr
Montreal
huberoy123
