Low hz rumble though sub only while stereo is on
Low hz rumble though sub only while stereo is on i have 2 0awg power and 2 0awg grounds plus aditional grounds connecting bed and cab of truck to frame. seems like a ground loop but i cant find it. i have a skar zvx15d.2 v.3 and a RP2000D
Where are your signal cables running? Are they near the power cables? If it is an aftermarket head unit... is it grounded well?
Power remote and v meter wires down driver's side And high end 6ch shielded coaxial bundle down pass side. The ground For the stereo is factory ground
Hmmm, hard to say. If it is "humming" at idle, no music playing... I would start physically touching cables and wires with your bare hand. Many times a suspect cable will either silence or amplify the hum. Then you can trace that wire or cable and correct the connection usually. Just a suggestion. It may or may not yield a result.
It's not Humming it sounds exactly like my exhaust Its weird
Sounds like a bad or weak ground ..did you ground to the body or frame ? Body and seat bolts are very bad ground spots in a truck on a high powered system... also its always best to measure your ground resistance in larger installs ...
what ^ said. amp gain setting info, test tones are at the very bottom...
559
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
713
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
krystofir2009
krystofir2009
U.S.A.
shredder2
just call me KeV
just call me KeV
