Subwoofer underpowered
Tbrad
Htown
im running the setup below and it just doesn't hit as hard as I would like. I have a feeling this system is under powered and would like a recommendation on how to improve.
10" CompC 4 Ohm SVC
CX300.1 Mono Amplifier
Prefab box may be a weak link, position in the vehicle may also be an issue which is why I said "as it sits in your vehicle".
Your amp is only going to be able to provide 150W to that sub (which should handle double that). You can fix this with an amp that makes 300W into 4 ohms or a different sub which provides a 2 ohm load to your amplifier.
All things being equal if and when you double power you can expect roughly the equivalent of 2 clicks on the volume knob more output. If you don't think that'll do it for you consider going back to the drawing board and digging a little deeper into your pocket to buy into some more output.
Literally everything about this setup is geared towards weak output (lowend sub, cheap box, only 150 watts, 10 inch instead of 12 or 15). This setup will provide some bass but it's not going to ever be "hard" or "hit"
When I see 300 watt systems:
27093
Seriously though, what are your expectations? Obvious answers are switch to a ported box and you need more power. You get what you pay for. If you cheap out on equipment you can't expect to rattle the earth.
687
To do this magic, should the microphone always be kept in the driver's seat or on the dashboard?...since that is where it must go in phase with...
LOL. Ya man. Its been busy. Im off today, but got stuff to do around the Casa.Be a Great sub man, and very nice amplifier. If you can swing a few...
18
Open screw holes sound like a little muffler, loose box panels sound like a massager on a wooden table.
20
Tbrad
Tbrad
Htown
metalheadjoe
