COMPLETED i need broken amps
Got a picture of the Soundstream? Might be interested in it as it is a older one and I am going to be doing a old school build in my Cutlass in 4 years so going to be looking for older stuff like that to put in it.
You can get that fixed at Amp Lab or any repair place. They will go through it and fix it. I would get it fixed as those are still nice amplifiers. Not too mention not cheap when they came out I remember the V2 going for around 350-450 dollars
Old School Amps. I have a few. laying around. S.Stream and few BTS series Spoken for ATM
So you have an 800 watt sub (1600 is a peak spec, ignore it) the SVR-10 - 800 RMS dual 2VC ohm wired in parallel for a 1 ohm load paired with an...
89
181
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
135
482
Eaudio2013
Eaudio2013
wodokz
    May 19, 2024
    May 19, 2024
