DISTORTION at medium to high volume level in KENWOOD KMM-BT506DAB + front
id start with making sure you dont have a bass boost or loudness feature turned on
then id set your eq all in the middle position, no boost, no cutting frequencies
that can help prevent clipping (a kind of distortion)
then, if your deck has crossovers, make sure youre using them. 80 or 100hz, should be good
if youre not using a crossover, than can allow your speakers to move too much, causing distortion. speakers can only move so much before they distort the signal
if all thats good, you need more power.. an amp
Sorry for not answering in a few days.
I will search in this HU about bass boost, it's new, so all settings must be from fabric.
I will search about crossovers and HPF filters and I will try if there is any difference with them (this is going to be a slow procedure, now I don't have too much time)
But I think that biggest difference will come with one amp, I think head's unit electronic doesn't have enough power (4x22 W RMS) to move all the coils of rear 35 W RMS speakers and 120 W RMS front speakers (well, first try I told you was with only one speaker, so...)🤔
I will post new comments when I have news to share.
Thank you everyone! and next time I will try to film speakers reactions with and w/o amp or crossover/filters.
One question, can I use crossovers or filters without an amplifier? should Iconnect them to speakers output head unit connectors? or RCA connectors?
Thanks!
U have to ignore that idiot !...thats the next thing i would do is check wires.i would run new beings how the wiring is old.
Hey guys, anyone with a DD-1 or other distortion detector in the south florida area ? Thnks
The amplifier will only amplify the waveform that you put into it. I think you have missed or are misinterpreting something here.
I don't think so, it is the standard radio/speaker combo that comes from factory, but I will do some research to make sure there isn't one hidden...
957
Dante1880
Dante1880
