SIA 1750 amp
Is the SIA 1750 amp too much for a Sundown Sa-10. v2 D4 wired at 4ohms. The amp puts out 1250w rms at 4ohms and the D4 is rated at 1000w rms so I was wondering if I should go with the SIA 1250 or the SIA 1750.
Either amp will be fine. Just get your sub in a properly tuned enclosure and the correct type of enclosure for the vehicle and tune properly and you should be fine
You could wire it to 1ohm and just use ohms law to set the amp to 1000w
V(ac)=√(watt×ohm)
31.6v=√(1000×1)
Take a multimeter set to ac voltage and turn the gain up till you see 31-32v on the multimeter.
Use a 40hz test tone with no sub hooked up
Set it then hook the subs up. You now have nearly 1kw of dynamic headroom
V(ac)=√(watt×ohm)
31.6v=√(1000×1)
Audiobahn already answered the question. Move on genius. Are we having fun yet?
The SIA1750 is a perfect choice. You have almost double the rms of the sub. That is perfect after impedance rise. Great choice.
Yeah, like Audiobaun said, big amplifier likes a big car battery and a strong alternator. If you wire your subs to 1ohm, you want to have an idea...
870
Good thing you bought the amp, then asked the questions.
  • Locked
The picture needs a piece of paper with your name and date in it, forum rules not trying to be a dick.
Out of those two for the money.. Id go with the Kicker. they still make great amps
146
bryanarriaga67
bryanarriaga67
Texas
Bobbytwonames
