Power and Amplified Speaker wire question
AnthonyO
Budget Banger Connoisseur
Getting ready to finish my trucks install tomorrow.
My dilemma. I have my power wire running down the drivers side of the vehicle. I have nine wire speed wire that will be running from my amp back up to behind my head unit to power my door speakers. I will be running my RCAs on the passenger side. Should I run the speed wire on the drivers or passengers side? My mind is saying drivers side.
And you (if you’re not a Ai BOT), for the sake of everyone in this forum, may want to quit posting, Your information is consistently off topic and incorrect when on topic. Providing bad info when dealing with some of this can be dangerous and may cause someone to blow something up or start a fire. Just stop.
As a general rule, RCA's and speaker wire should be twisted pair cable. If you must cross paths with your power wire, do it at a 90 degree angles (so across, not parallel with). Speaker wire and RCA’s can run parallel just fine, it’s the interaction between power and signal wire that can be problematic.
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
495
711
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
522
AnthonyO
AnthonyO
Minot, North Dakota, United States
Silicon oxide
just call me KeV
just call me KeV
