Enclosure Question
  • 6
GMC904
Tampa
I'm going to build a custom enclosure for my 2 JL 10w3v3s. I have a 23 Jeep Wrangler with the sky one touch top. I currently have the subs in a sealed pre-fab box that has .8 cuft per sub. I am thinking about building a ported enclosure with the subs downfiring with 1.25 cuft per sub. Should I have the slot port also downfiring or rear? This is my first convertible and I didn't realize how much it effected the bass lol. My amp is a Rockford Power T1000 1bdcp, wiring to 4ohms.
Hopefully someone more knowledgeable can chime in and correct me but I believe a bandpass box is the best thing in a convertible since the sound waves don't need to load off the trunk, roof, etc to get loud.
Downfire subs and port. A bandpass box would work very well, but they aren’t cheap to have made custom. A horn or t-line would work even better with the open top vehicles, but they’re huge boxes.
Have you considered under seat options? https://www.bing.com/search?q=under...0218DC806086C34C6DC&FORM=QBRE&sp=1&ghc=1&lq=0
This is my thought as well. Would be a much better box volume if you could buy the 12" version of those subs.
1.25 NET cubes. You have to add the sub and port displacement to the box. I'm guessing that you will be around 1.7 net before sub and port...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
711
GMC904
GMC904
Tampa
Buck
    May 19, 2024
    May 19, 2024
