What thhn wire is the positive and negative
No found it in my garage i know its a flat 4 trailer wire but thats about it and thank you
Its copper wire. it will work if thats all you have and do not want to spend any money on new wire. Its safe to use for car speakers. I know most Trailer wiring is like 14ga copper. It can be used. Just make sure you connect + to + and Neg. to Neg. on the speakers and at the radio. That wiring is pretty rugged and weather resistant for quite a while too. It should be just fine. If you rather buy some new speaker wiring? Search for 16ga or 14ga in size on Ebay or other sites
It should work just fine if the outer protective coating isnt corroding becoming brittle or copper wiring exposed.
Oh so I can run any of the thhn with the negative cable of the head unit and negative speaker and it works good?
You can split off two wires and use those from the Radio to the speaker be sure to mark or remember which wire you used for _ and + from the HU/Radio to attach to the speaker.
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
307
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
791
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
958
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
956
Malcolm.ross
Malcolm.ross
Canada
Firewalker
