Need New Surround installed on JL W10 in Canada?
Anyone out there know a good shop in Canada that can replace surround on JL W10? my cat thought she would like to chew on it:(
Replacing the surround is not that difficult. You can get a surround from lordofbass, Springfield Speaker Repair, or Midwest Speaker Repair. They will send the surround, glue, and instructions for a DIY. I would compare the difficulty to assembling an IKEA desk.
Probably won't be worth the cost of 2 way shipping to someone for repair (unless it is a W7), even then cost of surround repair kit is quite low and provided you're mindful about keeping things centered so as not to pull the coil off square and are gentle/careful in removing the old surround this isn't a terribly difficult repair.
502
380
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
417
623
Hank7.62
Hank7.62
Kamloops BC
Hank7.62
