Aftermarket stereo not working
Keiron Flanagan
Wigan
I recently decided to upgrade the stereo in my 2006 smart forfour so i can use bluetooth i have tried 2 stereos and neither are powering up you can here the power supply when connected from mechanical movements in the cd wht is the problem?
What are the two head units you have tried and are you using a prescribed wire harness? Did you wire up the antenna or ignition triggered turn on and the 12V leads?
The firat ine was a cheap chinse thing off amazon the next was a jvc stereo, ijust removed the 2 iso cables and antenna from the old built in stereo and plugged them in the new ones but no power on either,ive ended up with the orignal stereo back un till i can solve this as this still works.
Still not following. Do the two units you tried have a attena/ignition triggered lead and if so, is it connected? Might want to post what units you are trying to hook up and what the year make and model of the car it's going into. Unless you are just really unlucky, chances are you're missing something in how the aftermarket units are wired compared to the factory HU.
jvc kd-r741bt i just used the cables out the old stereo using the isi harnes that came with the stereo. The cheap chinese one already had the same iso connectors built in to it
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
699
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
858
Nice, well I think they will blow away anything you have running on your puter for sure. I've had good luck with the NVX components, hard to beat...
Keiron Flanagan
Keiron Flanagan
Wigan
Keiron Flanagan
