Please help
Jonathan nelson
Ok so I have two 12 inch Diamond Elite Series 12" Dual 2 Ohm Subwoofer 500W RMS subs. They say dual voice coil but only has 1+ and 1- speaker terminal on them. Is this possible? I was always told that if there dvc they will have 2+ 2- terminals.
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
That is strange there. Thats what Ive encountered with low voltage before . That Kenwood needed a Firmware update and that fixed that one when it...
17
Jonathan nelson
Jonathan nelson
Missouri
