Sound system is causing transmission shifting problems.
  • 5
bananapehl777
Hi all,
I am having some issues with transmission in my Subaru, and it's actually been a problem since I've had my audio system installed, I just didn't think it was due to the aftermarket audio system (I replaced valve body and have done countless fluid changes, had it diagnosed by dealers and other shops and they could find nothing wrong with the transmission, put $2k down the drain trying to figure it out). The big issue is that when I am accelerating and moving through the gears (like moving on from a light), the transmission will shift very weird -- like someone who does not know how to shift a manual; it feels like the computer messed up how to shift the gear appropriately and the car bucks. It does this only when I have my system turned on full tilt and playing bass, it will never do it if I have the system turned down or off. I've posted about my setup in the past, from this thread: https://www.caraudio.com/threads/ho-alternator-idle-conundrum.608986/. Everything is still pretty much the same now. Here is a diagram of how the subwoofer amplifier and important electrical wiring is. All electrical connections (grounds, battery conditions) are freshly cleaned, corrosion free, and are stripped of paint. All wires in diagram are 1/0 AWG except for the labeled 4 AWG. Battery voltage can dip into the mid 13s for a very brief moment when engine is revved around 2-3k RPM when bass note starts, then immediately jumps back to above 14 V.
I have set the amplifier gain using the multi-meter method measuring voltage across the subwoofers while playing a 40 Hz test tone (V = sqrt(Power*Resistance) - 34.6 V = sqrt(1200 W * 1 ohm)), so I don't believe I am clipping the signal.
I am at a loss what to do especially since I want to put a bigger system in someday, and it prevents me from really enjoying the system's full capabilities to the point where I don't turn it up at all because I don't want to damage the transmission. I have heard I need a cap or that I should bypass the grounds to the body and instead run dedicated ground wires, yet the car audio shop I go to said not to. I am assuming most people are able to drive their cars normally with these big systems installed playing at full volume and have no drivability issues? What am I missing?
I would suspect that a wire for the transmission control got disconnected or damaged during the stereo installation. It could even be that a pinched wire is getting vibrated by the subs and is causing the problem.
Without being there when the car is having the problem, I don’t think anyone can be more exact.
I suspect it's an ignition problem rather than a transmission problem.
Start with the basics: plugs, wires, coils, check engine codes.
Does the problem change depending on how hard you accelerate?
19
thats good to hear that sub/amp is good pair, well one of the front speakers on right side, im guessing it blew out because its the one that makes...
So I am planning to build a system in my Ford Excursion and can’t decide on whether I want to use an iPad mini with a sound processor behind it or...
bananapehl777
bananapehl777
Norman, OK
metalheadjoe
