How much area for sound to exit from downfire box
How many in^2 of area do you have for the exit holes under the box? That's what I always look at, just like how you'd design a t-line, based off the Sd of the woofer, somewhat. Like, if you have a total bottom opening surface area that's at least the Sd of the sub or maybe the Sd + port area net, then it sort of shows a relative restriction won't happen, because the bottom of the box has more radiating area than all radiating surfaces of everything in/on the box. That's one way to look at it.
Buck be da (box) MAN!
Buck, great idea. I did that tonight, and it actually didn't wheeze like a fat guy trying to run a marathon. I am going to put two windows that match the front 3 on each side and call it for now. Doxquzme, I am sure your plan would work as well, certainly better than what I am going to do. I kind of like the look of the arches. I am far from a SQ guy, I just wanted some bass to go along with the mids and highs.
I am going to have to come up with a good way to hold it down though. It dances around like crazy. I had to lean on it to keep it from rattling. Every box I have ever built was carpeted and either bolted in place or held in with the seat. I bought some adhesive rubber weatherstrip to go under it to help dampen it.
Thanks for all the help and suggestions.
They were awesomne man. The components and Coax speakers I shoulk have kept. Theyre amps were pretty nice too. I never ran any of theyre subs...
20
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
If your audio system constantly draws more amperage than your alt produces, it will drain your battery, to the point of the battery needing to be...
14
The one and only mtx amp I've run was like that (it was black with the fake chrome platistic badging back in '01 I think) the first time I made a...
41
4K
You need something more like a pro audio woofer. You want a really light Mms with a lower Fs. Idk how much loudness vs range you want, but a...
14
racin69z
Junior Member
racin69z
Jackson MO
racin69z
