Wiring harness
rob2421
us
I’m unable to figuire out which wiring harness I will need for a kenwood radio install in a 2015 Toyota Corolla. I know I will need one with canbus so I can keep steering wheel controls and back up camera. The receiver is Kenwood model DDX5707S. Any help will be appreciated
A quick eBay search yielded many similar results.
The black connector in the end is a standard 16 pin that is used accross the industry, so plug and play should be possible.
I ordered the one from eBay but the connector does not fit into the receiver. Attached pic of connector type I need.
If you still have the original Kenwood harness, you will need to clip off the new black one and splice it in. It should be easy since it is color coded. If you do not have the original, this one will work.
So is the radio harness spliced direct to the OEM harness? There is no adapter harness?
If the plug matches, you just need to match the wires up. I re-made the harness for my audison amp, and the hardest part was getting the speaker...
Based off GM pickups of the same year (and that was GM), It SHOULD just be for the vehicle sounds that play through your stereo, such as the door...
Kicker 46CSS654 CS Series 6-1/2" component speaker system chose these for the front chanel Kicker 46CSC654 CS Series 6-1/2" 2-way car speakers...
rob2421
rob2421
us
rob2421
