Do i need caps on my tweeters ?
Replaced them with DD a series ceramic dome which I honestly like more.
Just need to order the pods for my m3 carbons so I can lower the hpf on my tm65mkiv.
That and finish my sub stage so my front sub doesn't have to play down to 30hz
Very Nice! I have some Dayton 80 rms tens I am thinking about placing under the front seats on my next build out. I have a set of HO series as well that may fit?
I did an adire koda 8 for now but I'm considering swapping it to a Dayton ho 10. More cone area for more midbass. But I might not need to. I might can just add more power once I raise the hpf to about 50hz.
I was trying to wait on sundowns sd5 10s but I've been waiting over a year at this point
503
381
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
418
623
Bass so loud it HZ
Bass so loud it HZ
IN, United States
