Levitation- Standing Waves
Distance is frequency, different distances change resonance due to wave speed and length. This is just a great visualization. When he moves the reflector and the levitation stops, that seems to me like playing a note, then suddenly making an enclosure out of resonance with the speaker frequency, so stored energy resonance is quickly lost. That's why there's different lengths to ports in sound; you lose so much energy out of resonance.
Good read there gets into 1/2 wave and 1/4 wave, which a subwoofer t-line is a 1/4 wave tuned structure. Dude talks about 1/2 wave resonance with the reflector plate distance from speaker in the video.
"Here's a frequently asked question: if a quarter-wave is 90 degrees in phase length, why does it transform you 180 degrees on a Smith chart? Consider that here we are plotting reflection coefficients on the Smith chart. Thus, an imaginary signal that you send through a transmission line of one quarter wavelength must travel fully half a wavelength, since it travels down the quarter-wave line, gets reflected, then returns down the quarter-wave line."
There's an astonishing similarity between the physics of the resonances of electronics (like a wire) and the resonances of air with sound (like a sub t-line box), like how I've designed boxes. It's all just waves moving through a medium. Your different boxes for the same sub change the electrical nature of the sub the amp sees, so keep that in mind. In other words, different box types and styles greatly impact sub coil movement through the motor magnet, which (can) greatly change the electrical impact of the sub's stress or feedback into the whole system (sub impedance changes).
There's an astonishing similarity between the physics of the resonances of electronics (like a wire) and the resonances of air with sound (like a sub t-line box), like how I've designed boxes. It's all just waves moving through a medium. Your different boxes for the same sub change the electrical nature of the sub the amp sees, so keep that in mind. In other words, different box types and styles greatly impact sub coil movement through the motor magnet, which (can) greatly changes the electrical impact of the sub's stress or feedback into the whole system (sub impedance changes).
"The comparison between an acoustic duct and an electrical transmission line is useful in "lumped-element" modeling of acoustical systems, in which acoustic elements like volumes, tubes, pistons, and screens can be modeled as single elements in a circuit. With the substitution of pressure for voltage, and volume particle velocity for current, the equations are essentially the same.[2] Electrical transmission lines can be used to describe acoustic tubes and ducts, provided the frequency of the waves in the tube is below the critical frequency, such that they are purely planar."
Nice little read on visualizing how 1/4 wave resonance works, such as with a transmission line:
A subwoofer 1/4 wave resonator:
Very simple way to make good sounding bass is just put your sub in a port that's the Sd of your sub and 1/4 wavelength of sub Fs or whatever frequency you want to peak bass at most. It's that simple; that is a basic subwoofer transmission 1/4 wave line enclosure.
Buck
little alien on campus
Buck
Inside of a pyramid
Buck
    May 19, 2024
    May 19, 2024
