correct method to balance the levels of each speaker
surreal89
19
Italy
Good morning.
Is it appropriate to balance the levels after setting the cuts, slopes and crossovers of each speaker? Or should we rebalance the levels without applying any cuts?
the procedure I did was...
first I sketched the cuts without having made any measurements, then the levels and then the time delays.
Maybe I made a mistake.
perhaps I should have first adjusted the levels without filters, then taken measurements with the microphone, decided on the cuts and then applied the delays.
I should have applied a filter only to the tweeter to avoid breaking it, right?
Set your base line filters first, I never do anything until that is done. What are you using to tune, the HU, DSP?
I use DSP.
therefore I first impose some initial cuts, basing the intersections on the measurements taken in flat with pink noise.
Can I proceed with the levels immediately after?
id eq at the db you listen to the most often. our ears dont hear things the same, at different volumes. why tune at 60 dbs, when you listen to 90
787
It should work well enough for you to get solid connections. That’s about the same price I paid for this one, and I‘d bet all the cheaper...
I downloaded 2 db readers for my phone to see how loud I listen to my music. Sadly they both tapped out at 95db. So for a 10min drive they both...
25
Simply put its an oldschool simple way of keeping the midbass in phase with each other when they are firing at each other in the front...
780
surreal89
surreal89
Italy
surreal89
