Air space
  • 6
I try to recommend what I can with what information is given. Hopefully you can get the enclosure you need and want for your subs.
My apologies If I did not give the best solution to the questions asked of within the other thread. I went off the information provided without making a customized enclosure for that space provided and given.
Round flared aeroports would give you some extra air space. I did a 4 cube enclosure for a 15 not long ago and the aeroport saved around .5 cubes over the slot port with the same air space. You’d almost need to go custom to squeeze everything you can out of your space.
No don't apologize I totally understand and the information you provided helped alot
Look at the Alpine Type S subs.
19
Thanks for the feedback. It was a long shot but there will definitely be much more powerful subs in the trunk, so clearing it out isn't an option...
I have confirmed through JL that these subs have just over 1inch xmech. As long as there is 1inch clearance in front of the front edge of the...
Charlotte
    May 19, 2024
    May 19, 2024
