1600 watt amp
Bradda_dan
I have a 1600 wat amp from audio solutions. I have it wired to my two 12"s and the guy never told me how much it can handle or the ohm load or anything. And i canʻt find specs anywhere. My amp is running hot off the two subs so i unhooked one and now itʻs running at 5ohms. But still hot. I have nonodea whatʻs the issue. Itʻs not bridged or anything. Only a 2 channel amp. "As2.800" is the name and the brand is audio solutions. Any ideas or tips would be nice. Thanks from hawaii!
Never heard of the brand either....gotta be some knock off or something and doubt very much it is 1600 watts.
Could be a number of reasons why it runs hot: enadequite power/ground wire running to it, real low impedance final ohm load, which the amp may not handle, etc.
Need more info and pics if you can.
any 2 channel should be able to run in stereo so just run 1 channel to each sub if it gets a little warm thats normal after 15-30 mins.. gain set to high?, gain should never be higher than 1/2 way up bass boost off or very very low., if subs are single vc 4 or 5 ohm u need mono amp thats 2 ohm stable,, if they dvc subs each vc showing 5 ohm its probably 4ohm dvc just reads high wire each 1 to 2 ohm (or 2.5 whatever) then run amp 2 ohm stereo 1 channel per sub u will get more power that way again every amp should be 2 ohm stereo stable (not 2 ohm bridged)
What brands are offered in your location? Ive heard that Ground Zero and Stetsom are a great option and even Taramps
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
Bradda_dan
Bradda_dan
Kapolei, Hi
audiobaun
maylar
    Jun 2, 2024
    Jun 1, 2024
