2 Alpine R-SB10V on S-A60M?
  • 2
nealuss
Hello all, first time poster here. Title pretty much sums it up. Basically I currently have one Alpine R-SB10V (Halo series linkable prefab) on a S-A60M. The amp is rated for 600w @2ohm but the dyno sheet states it tested at 850w rms. I just bought a second R-SB10V I will be getting an R2-A150M (1500w rms suggested by alpine) when I can afford it, but that may be a couple of months. Should I go ahead and set up the second sub with the amp I have or just leave the 1 until I can get the right amp? Will it be better, worse, or about the same?
Being that the sub is wired to 2 Ohms, you will have to wire the other in series for a 4 Ohms load. That will then be 165 to ~220 watts RMS per sub. That should sound better than 1 sub at 600 to 850 watts RMS.
Re-edit- will this be in a trunk?
488
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
702
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
nealuss
nealuss
Clayton, NC
maylar
    Jun 2, 2024
    Jun 1, 2024
