2 FI BL 12's.... NEED BOX HELP!!!!!
  • 6
Nsjabauanabagaoakddb3
Going on a IA mono 20.1
2 FI BL 12"s
slot, square port.
flush mounted.
what size port and box? - i though around a 6" wide port and 7 cubes
should i double baffle and triple baffle the sub mounting side?
or
is is bracing all i need?
if so...
what type of bracing?
max dimensions are (this is including the space i need for 3/4 mdf [take into mind the baffeling as it subtracts from the numbers even more]):
width (driver side to pass side) - 40
depth (ground to roof) - 23
length (headlights to tail lights) - 20
If you plan on giving them their RMS wattage, stick to 2.25ft^3 each with a tuning in the lower 30's. Overall volume before sub and port displacements will be about 6ft^3. You may or may not have to double up the mounting baffle, just depends on how you have everything laid out.
i put them in 7 cubes at 36 Hz. 6" wide port, triple baffled the mounting layer and doubled all the rest. its going to be a heavy ***** but solid. im going to skip on bracing because oh how my joints are set up. i think i will be fine with wood glue, pressure and a finish nailer. pm me your number and ill send you pics as i build it.
You put two strong 12s in a 7 cube box? Ripple city. Gonna sound like ish and be super boomy with an awful low end peak.
This. I personally wouldn't go over 4ft^3 for a pair. The thing that ***** about these low Q and Vas woofers is the need for a smaller box and a lot of power to get a decent response curve out of them while keeping output high. Granted, most people aren't looking for a smooth response if they're getting these kinds of subs.
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
4K
983
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
Los Angeles
Buck
maylar
    Jun 2, 2024
    Jun 1, 2024
