4 channel running different ohms, safe or waiting for disaster?
  • 5
ThxOne
Premium Member
The Boss
Silly question here. If I decided to run 4ohm tweeters off channels 1-2 then ran 2ohm mids off 3-4... will the amp even care? Since ohm loads change constantly while music is playing this shouldn't affect anything right? Or am I missing something? I ask because I don't care so much for the way these CDT tweeters (2ohm) sound and I may run my Image Dynamics or my DD tweeters. Both are 4ohm sets. My CDT mids are dual 4ohm voicecoils so... 2 ohms. All actively ran of course.
The amplifier shouldn’t care. On most 4 channels, the only thing shared between all 4 channels is the power supply. 1 & 2 are otherwise completely separate from 3&4.
148
381
10
768
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
445
ThxOne
Premium Member
The Boss
ThxOne
The United States of America
audiobaun
maylar
    Jun 2, 2024
    Jun 1, 2024
