5000K Amp or higher
  • 2
Evyn1
CarAudio.com Recruit
65
Looking to buy:
Taramps 5000K Smart Bass.
Or Digital Designs M 5000.
What is the pros and cons between them?
Taramps 5k Smart Bass looks good for under 500.
Digital Designs M5000 looks promising for 1,300.
My Subs:
(1) DD9518 SC
(2) SSA Zcon 12s.
There's a reputable seller on DIYMA that is selling a Smart 5K for $350
THis thing is a beast, used the 3K and it is a great amp.
- OR -
Thanks yeah!
As far as performance and sound…
Question?:
Digital Designs M5000.
Taramps Smart 5000.
What one is going to have the most raw performance?
Because I threw on an extra spider for the Zcon 12s, and super charged the DD9518.
With that control I could easily use the Taramps.
Two different boards altogether, half-bridge Korean versus Full-bridge Brazilian. Not a great comparative really, two different beast. For the DD money, I'd look into one of these, Full on half bridge Korean amp too, 8K
If you're considering a high powered full-bridge like Taramps, you must have good stable voltage and (strongly recommended) a lithium bank too. You're going to need electrical support for either.
The Mechman Alternator 260 Amp.
Big 3 Grounding.
And Caps?
The Mechman guy said I can run a 10k Amp straight off my Yellow Top.
Was thinking about a trickle charge to a 2nd battery.
And run it off that initially.
Then the Amp is separated from my Honda.
Run your yellow top and one of these in the rear, won;t need the alternator upgrade most likely.
I would consider a Glow VOltage Series 3 for shear instantaneous burst.
Or, a series 2 if you plan on just being loud and also having a bit of reserve.
I'm running the Series 1 for a 4500 watt system and it has a lot of capability and a lot of spare anp hours for off the alternator use should I want.
I would advise 2/0 gauge +/- front to back, parallel grounded.
Best bang for the buck 2/0 OFC wire
Black is $4.30 ft (min 25ft)
Red is $4.62 a ft 9min 25 ft)
Article on parallel grounding
https://www.bestcaraudio.com/car-audio-myths-you-cant-ground-a-car-audio-amplifier-to-the-battery/
That’s great Docquzme!
You think I can get away with running it straight off the yellow top as it is now?
And the big 3 ?
The Full Bridge Amp forsure!
I like (and use) full bridge for subs. They are not all created equal though. Still, I ran the Hooligan 3k 9DS18 all Korean half bridge) for a while in the previous hatchback, dynamic and powerful, loads of headroom , not quite as efficient but very dynamic. I have a Soundigital 2400.1 that I'm going to use on the Mazda build starting in May. I think Soundigital make one of the better fulbridge amps on the market but they can be a bit on the expensive side for the feature set one gets.
I don't need a lot of features on any of the amps I use, full DSP so the rest just comes along for the ride. My front stage amplifiers have zero x-overs or anything else besides gains, straight signal from the DSP to the amps and out to the speakers.
And the big 3 ?
Maybe, depending on what you endup with or think you will actually use. With the GLow Voltage setup and parallel runs parallel grounding, should be okay to around 8000 watts.
You may only need 1/0 from front to back depending on the length of the runs as well. 2/0 is what I got not thinking alot about it, would have been fine with 1/0 now that I think about it.
146
  • Locked
339
Amp
338
389
Evyn1
Evyn1
    May 19, 2024
    May 19, 2024
