Amp not working?
M477430
So first off I just wanna say this is the first time I've ever put a system in a car, so take it easy on me. So this afternoon I was working on getting my alpine mrv f450 amp and a jl sub I found(I know for a fact it works) in my 03 corolla, last week I put in my pioneer fh-x721-bt or 720 and it all works well except the sub, the amp turns on the deck works but no matter where I put the rca in the amp it just doesn't work, and I've tried changing around all the outputs to the sub but nothing. The blue light on the amp turns on so that's where I'm confused, I tested the rca with a headphone to rca cable, also doesn't work. I don't know what else to do, I've tried almost everything except for the really time consuming stuff. If anybodys wondering I had the amp in 3+4 trying to bridge it and I tried switching it to just the 5 channel also didn't work. I don't know what else to do im incredibly appreciative of any suggestions or help anyone can offer. Thanks in advance.
Just because the amp turns on doesn't mean it's good sounds like bad rca out puts or bad mosfets. If you attached and headphone rca jack directly to the amp. Then that rules out the decknor bad rcas. So the amp is the issue. So check voltage and ground continuity with a dmm start there
u could take amp out test it in a friends car., if it works there u know it's hu, wires, rcas or ground.. I'm actually testing friends amp in my car Tuesday don't work in his but it lights up..
There isn't much it can be. Pull the amp turn on wire out of the amp, and just run a wire from there and touch the distro block will activate...
The amp should still turn on regardless of your settings. Those settings will probably cause almost no power to come from the amp, but thats a...
Some equipment like AMPS comes with it no owner's manual. So the lights blinking on or off has to be taken somewhere else. Search engine. Car...
I updated the original post to simplify it a bit and re-frame it with the new Scosche floating ground adapter. This adapter *is* different, as it...
I’d suggest taking a methodical approach. Start with things you know work. Then add one thing at a time. Test the addition with a scope. Keep...
M477430
M477430
Mississauga, On
BOOMINGRANDPA
maylar
    Jun 2, 2024
    Jun 1, 2024
