Have a few questions on designing my first box
  • 6
So im buying 3 12inch subs and this is my first time buying them that arnt already in a box and having to build my own. After reading the sealed vs ported thread im deciding to go with a sealed design.
The subs are Boss P126DVC http://www.sonicelectronix.com/item_23654_Boss+P126DVC.html
It says that they require a min and max of 0.8 cubic feet Box Volume... so how do I figure that if I decide to put all 3 in one box together? Or is that a bad idea and I should build them 3 separate boxes?
What is a good program to use to design my box because all the ones I have tryed ****.. any help would be greatly appreciated.
x2, Boss = junk. If you already have them and insist on running sealed, just build a single 2.5ft^3 box, or a single box with two dividers giving you three equal air spaces within the larger overall box.
No to those aswell. My favorite budget subs ( don't know about the newer models) were the cerwin vega vmaxs With the pink surround
Also I have 2 of theses amps but bridged they run 4 ohms but the subs are 2 ohms so can i wire it for 2 ohms w/o messin wit the amp or should i just run both of them in the 2 channel mode 600watt 2ohms both of them how would i wire 2 amps to each speaker? any suggestions on wiring these would be awsome
they are 2
# Model: T-1802A
# Bridgeable Amplifier
# 1800 Watts Power Handling:
# 1800 Watts x 1 Channel @ 4 Ohm (Bridged)
# 1200 Watts RMS Power Handling:
# 600 Watts RMS x 2 Channels @ 2 Ohms (Stereo)
# 300 Watts RMS x 2 Channels @ 4 Ohms (Stereo)
Thanks for the tip my buddy told me Boss was good...
What about these subs
SPL SP3-15 SPL SP3-15 (sp315) - 15" Subwoofers - Sonic Electronix
I like them and they require 2.0 cubic feet so what i need to know is when i put both of them into one box do i make it 4 cubic feet space inside or is it more complicated than that?
Also any good programs to lay out the box designs?
Your buddy lied to you and you should smack him for doing so. Boss is trash. maybe you should post up your max budget and let ppl here suggest subs for you.
I think he'sasking because electricity is often compared to water to make it easier to understand. It can be helpful, but it can be misleading...
The bigger the gauge number, the smaller the wire. 8awg would be smaller than 7awg. Yeah, go with 4awg. 7awg sounds like it must be for an...
I found this, can it be done with snapon modis ultra scanner which i have...
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
500
L3gitjackass
L3gitjackass
Sacramento, CA
on1wheel01
maylar
    Jun 2, 2024
    Jun 1, 2024
