Help with with components. Polk DB
Yes, no processor here. Lol.
And Yes fronts and rears on same amplifier.
I plan to deaden the doors and a few other areas when I receive my plans and build my new enclosure.
Im still interested in a 3 way setup... It may be more beneficial to purchase a 4 channel amp to separate the fronts and rears.
A 4 channel could also be useful in a 3 way?
I suppose I will deaden the hell out of my doors and seal them up as much as possible and see how that sounds. More than likely I'll move the tweets up to the A pillars.
Idk. I still ponder a dedicated mid bass woofer and some different tweets...
I'm pretty lost when it comes to SQ front stage, only used to keep up with SPL in the past!
I came across those too. Seen all the drivers out on the alibaba sight for sure. Wonder who is making them for PPI? Looked long and hard at those...
28
173
457
TFD
Unknown
TFD
H-Town, Missouri
TFD
maylar
    Jun 2, 2024
    Jun 1, 2024
