How to match Sub-woofers To Amplifiers
danmathew
Speaker Champion
Here i m bringing you clear ideas about how you can match Sub-woofers To Amplifiers.
So you’re in the process of coming up with an ideal car sound system? Matching subs to amps is a crucial step in building a powerful audio system for your vehicle. Both amplifiers and subwoofers are vital components of an excellent audio system. A subwoofer operates as a speaker the reproduces a low-base sound while amplifiers boosts increases the sound signal thus increasing volume. The secret to getting a great bass is ensuring that your am and the subwoofers are evenly matched to work properly. This guide will assist you to figure out how to do that enjoy quality sound. We’ll approach the issue from both sides of the system that is covering the basics of power matching, the number of subs you require and impedance.
Power matching and part picking is simple. Making the system do a solid 135-150 db with good bandwidth and overall musicality on a tight budget is where the valuable information is at.
You might want to delete your Part C. Thats some bad juju right there with all those recommendations yikes.
for example this one....
"Two 4-ohm dual voice coil subs
Two 4-ohm dual voice coils subs offers a great wiring flexibility. You get various ways of hooking up the combination to acquire that bass you’ve been looking for. A 2-channel amp would suffice this combination. When you wire the subs with a bridged 2-channel amp, the total impedance presented is 4-0hms."
a single monoblock with the two d4 subs wired to 1 ohm is optimal and cost efficient in this case providing the most power as well. two channel amps dont have a subsonic filter either so if they arent running a sealed box, they are screwed if they dont know their limits and accidentally play a low note below port tuning full tilt.
What is this?.. some attempt to educate this forum?...
https://speakerchampion.com/match-sub-woofers-amplifiers-proper-guide/
Thank you immensely for your valuable input...
https://audiolegion.com/collections/monoblock-amplifiers/products/al1200-1d-1200-1d-monoblock-car-amplifier
Hi, I'm new here and the current car audio that I've had for a month is my first in my life, so I'm asking for your understanding 😉 I'm starting...
  • Locked
COMPLETED WTB Match UP 7 BMW
text me +1 (706) 300 5660 for quick response, i have the Match UP 7 BMW for sale at a secondhand price, stay safe
danmathew
Speaker Champion
danmathew
Los Angeles, CA
BOOMINGRANDPA
