COMPLETED I need this spacer adapter
  • 2
terryracing86
missouri
These came with adapter kits for 90s Chevy trucks. Would anyone have just the angled spacer part they would sell? Here’s a pic of what I need. Either burgundy or black
So you have an 800 watt sub (1600 is a peak spec, ignore it) the SVR-10 - 800 RMS dual 2VC ohm wired in parallel for a 1 ohm load paired with an...
88
181
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
135
482
terryracing86
terryracing86
missouri
audiobaun
    May 19, 2024
    May 19, 2024
