**Issues** Installing a pioneer stereo in my 98 Tercel
  • 1
Hi, I had some issues trying to connect a pioneer deck into my 98 Tercel.
I haven't bought a harness but I made one Here is the link to some photos.
The stereo, dome light and clock are working just fine
My problem now is that my dash light aren't connected, I can't put my car to drive, I don't hear the chime when the headlights are still on and such.
Could someone tell me what I have to do or what I did wrong to have all my issues fixed.
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
611
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
chris.lepage442
chris.lepage442
Montreal, Canada
chris.lepage442
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
