JL Audio 12W0v3-4 OR Infinity 1260w subs
rovertnamrod
24
florida
any opinions on which one is better and why? i am looking for a high sound quality setup with tight, punchy bass that plays very accurately. i'm not worried about extreme loudness. which would have better sound quality?
i noticed the infinity 1260w has a louder decibel rating and a lower required box volume than the jl audio 12W0v3-4, so how would that affect sound quality?
oh also this sub- Pioneer TS-W309S4. how good is it compared to the others? it has the lowest minimum rated frequency (20hz), the jl audio is rated at 22hz minimum, and the infinity is rated at 23hz minimum. will either of these subs actually push out notes that low?
that infinity is probably the best of the three in terms of what you're looking for, but search around this forum and you will realize there are way better subwoofers for an sq setup than what you find in stores. check out image dynamics for some sq equipment
why do you consider the infinity the best of the 3? oh, i'm sort of on a budget too, just want a sq setup but don't want to spend mega $, needs to be reasonably priced.
also, does the 3hz that the pioneer plays lower make much of a difference?
ya i checked out image dynamics. they seem pretty good. how good is the ctx124 sub? does it really play 16hz frequencies? are there any other subs out there that play really low frequencies like that?
Now coming out to the wholesale distributor, Sub sonic car audio new brand owned by selelectronics since 2000. Look for new subs ,amp, empty...
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
217
rovertnamrod
rovertnamrod
florida
rovertnamrod
maylar
    Jun 2, 2024
    Jun 1, 2024
