Need $100 comps.
Sounds like a poor tuning issue. You can literally make any set sound good with proper signal processing/tuning, speaker placement, acoustical door treatment. There's more to sound quality then to just buy a set of speakers and toss it in on the door with an amp then playing around with the EQ
What Size? 5.25s or 6.50s.Ill say this..I have a set of Polk DB 6.5 coax, that have lasted me for the last 3 yrs, and they sound excellent on HU power and sound fantastic on 50+ rms with preped doors.They get loud and play very clean on a good clean ,low tdh amp..Infinity are very nice as well
6.5s, and I know there's more to it than that, this is just all I have.
If you know, then you should not pass off speakers just because you heard them in an improper setup. A pair of flea market speakers can be made to sound better than 200$ components if the install, tuning, processing, deadening etc are done right while the 200$ components are improperly setup.
Polk audio db comps. I ran them on double rates power for years with no issues. Sound great and kept up with 150db + ad they are weather resistant
I really like Polks, they have been around for a very long time,and do sound very good for the money..JBL, and Infinity also
We pulled a set of Polk MM crossovers out of a door the other day. They where in a bag that was filled with water that looks like it was there for at least a year. Still worked
There is a build log going on of a Charger/Ramrod that has some experience with the NVX speakers that can give you his experience of using them to get some feedback on how they sound/perform
Well I didn't spend $1,500 on my system. I only have $50 and 36 hours of labor in my sub setup. I have an Alpine MRV-F345 on the way, and I need component speakers for that price. If you aren't going to help me with what I'm looking for, don't reply. Thanks.
so your labor is worth nothing? I wouldnt work for 36 hours for $1550.
that said, I did help. im trying to help you save money by not buying GARBAGE
517
383
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
420
629
Brian21699
Brian21699
Vancleave, MS
Brian21699
