Need an amp for a SA E12 D2 (2 ohms)
  • 2
We have the Precision Power i650.1 in stock and it's rated for 400W at 4 ohms. I have this amp in my car and it does a really good job, plus it's really small.
sorry, im new to this stuff, but the sub says 2 ohms, and the amp says 4 ohms. Does this matter? would it make a different rms figure? and how much is it?
The "D2" means dual 2 ohm voice coils. You can wire the sub to either 1 ohms or 4 ohms, depending on if it's parallel or series wiring. This doesn't change the power rating, but it makes an amplifier put out a different level of power in most cases. For example, the Precision Power i650.1 is rated for 400W at 4 ohms and 650W at 2 ohms.
Ohms is the resistance against current flow. Less ohms is less resistance against the flow, like water going through a hose. Bigger hose = lower resistance.
On the i650.1 this is how you should wire the sub to the amp:
876
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
EC11
EC11
Cincinnati
trumpet
maylar
    Jun 2, 2024
    Jun 1, 2024
