Need help with amp and subs
Not gonna lie. Money is tight at the moment. We'll, for audio equipment it is. I came into this project, thinking it was gonna be gravy. I could use my stuff and it will be booming. After learning alot from y'all, I realize that my equipment is ****** and I really don't wanna wire this up, bc in about another week, I'll be spending some money on better stuff.
So that being said, I'll buy my amp used. I'm pretty savvy at getting deals. My thing is, when looking for a good amp to power 2 good 12s, what specs on an Amp should I be looking for? That's the big question for me
Sent from my SM-G950U using Tapatalk
all this depends on how much $ what type/size box and and all that.. i'm sure my old system with 1 ported pioneer 3003 would be great for u and 5 times louder than the 2 subs u were about to run.. box is also a problem $ wise unless u build it.. i think u should get that jbl amp cause it's wayyy better than anything u find for up to twice the $ and a decent 12 sundown E bstock is $95 they have 30 day warranty so get amp hu installed get 2cf ported box then order sub.. there are other subs but not many as good for same $ except the 3003 i had..
Ok. That's a plan
882
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Packers27
Packers27
Dyersburg TN
Packers27
