Need help with sub box design
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with 2-subs in a sealed box. The complaints were hollow sounding bass and the air turbulence sound coming from the port.
Back in 1997, I started messing with parted enclosures. This was a time when sealed boxes were the common design for SPL competitions. After sitting and listening to a ported enclosure, I realized how to fix the ported issue. The hollow sound comes from the plastic pipe reverberating the sound as it travels down the pipe. Same thing as screaming down a plastic pipe and sounding like a robot on the other end. The rushing air noise comes from a mass pressure of air trying to flow out of a small port. So, the fixes were simple. Design a port that doesn't vibrate and is large enough to allow air to flow easier. Also, it dawned on me (DUH) that sound was coming from the port, so if I made the port bigger, more sound would come out. My box design caught the attention of a few manufactures, such as Rockford Fosgate, JL Audio, and Kicker. My box designs also started to dominate the DB drags in my area. A single sub, in a ported box, out performed 3 of the same subs in a sealed enclosure. At the time, I worked at DOW Stereo in San Diego.
With that said, I would go with a large port opening that is made using, at the least, 3/4" MDF. A square port put out more sound than the slash port. Tune it around 40 hz. that will give it a really nice bump in the octives.
currently I am using 4g wires for my ground and power (1-1.5ft for ground and like 16ft for my power) and no I did not sand the area for the...
100
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
This thread is over a month old. Shame I missed it, the whole thing is shameful and hopefully OP made those people give him an install that...
CarAudio.com Regular
Old_Slapper
    May 19, 2024
    May 19, 2024
