Ohm Load affect SPL?
I ran both positives to positives and negatives to negatives, used all 4 speaker inputs. That should read 1 ohm correct?
Wrong, completely wrong. You need to read up on ohm loads, how to properly wire subwoofers and learn how to set gains properly before you blow a perfectly good sub. THERE IS NO 1 ohm load possible with a D1 sub. If you wanted a 1 ohm load you have to buy a D2 sub.
here's the wiring diagram for all possible wiring for a 1 ohm dual voice coil subwoofer.
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
It also lowers the amps efficiency and raises the current draw.
643
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
435
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
RChillin
RChillin
Kansas City
RChillin
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
