PA1.5000d amp, is it any good
hey guys I have a soundstream amp right now but it keeps clipping and the highest I can turn it up without clipping is no where near what a zv4 12 can do ( that is why I have) so I am wondering if a PA1.5000d will power my zv4 12 thanks guys!
move away from soundstream if you want your sub to slam.
do you have any recommendations, trying not to break the bank so I'm looking for in the 500 or lower range if possible
The soundstream tarantulas are decent even the Picasso's are decent. There not what I'd call competition amps but they are decent for the money.
You need about 3000 for the sundown so I would suggest starting there..
The PA 5000.1 is the Picasso 2500 which will probably be closer to about 2000 so you really need something more powerful I have a good suggestion for you..
Synergy Audio WFO 35.1D 3,500w RMS Mono Block - SSA STORE
X3.60 - Soundstream Monoblock 400 Watts Class D Amplifier
The soundstream tarantulas are decent even the Picasso's are decent. There not what I'd call competition amps but they are decent for the money.You need about 3000 for the sundown so I would suggest starting there..
500+ for the x3.60?!?! are you nuts dude
What impedance is your zv4? If it's dual 1, then running two smaller amps strapped is an option I've seen a couple of people use for cheap power. Might not be the most ideal option, but should work.
How is this a classifieds thread?
156
387
  • Locked
692
Amp
503
Carsonb99
Carsonb99
Greenville Mississippi
CoolHandMark
maylar
    Jun 2, 2024
    Jun 1, 2024
