Planet audio 3000 watt monoblock pulse series???
  • 2
grillmaster
texas
I’m new to systems got no idea what the settings should be on my amp, it’s pushing a 12” skar vxf-12 D2 but everything is wired to one ohm. Friend of mine started thinking he could adjust it better than what it was . Now it sounds week as hell. I just found out that this particular amp apparently flunked the dyno test eventually I’ll get a better amp .
In the mean time any help on what I should set the amp settings to resemble what a descent system should sound like, would be greatly appreciated ! Turn them shits up my friends and thanks for your time if you respond .
Read the instruction manual, make sure your gain is set properly and follow the other instructions for tuning it. There may also be some instruction videos on you tube or Planet Audio website. FINALLY, keep your friend away from your system.
Thanks man I’ll give it a try I’m usually pretty bad at this kind of stuff. I wasn’t sure if there was a website or something that had a picture I could look at and just mimic the settings on my amp. Prob wishful thinking. And don’t judge I have now idea what does what on that thing have a good one .
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
213
grillmaster
grillmaster
texas
grillmaster
maylar
    Jun 2, 2024
    Jun 1, 2024
