Simple amp question
Those subs can be run at 1Ω each or 4Ω each, which leave you with either a .5Ω or 2Ω final impedance. Since most smaller monoblocks don't do well at .5Ω, you'll want to find an amp that does ~800 watts at 2Ω.
The CT Sounds 1400.1 will do that and a bit more at 2Ω and the 900.1 will do close to it for a bit less money.
I went with those simply because they fit, the cutout is round, and the hole will take a 6.5 coax. Cutting a square hole in a boat for a speaker...
21
5K
I think you're going to find this is true across the board. Technology has come so far at this point that even the absolute rock bottom unit that...
I would run a pair of 15s in an suv.. or run 4) 12s
24
No Issues out of my CT Sounds amps..EQ, 6.5s. There is not one company out there that hast ever had a perfect QC run that I can think of.Hard to...
monarch8
monarch8
Missouri
n2audio
maylar
    Jun 2, 2024
    Jun 1, 2024
