Speaker amp on subwoofer pre amp outputs?
  • 2
C4PT41N3NZ0
I'm thinking about purchasing a kicker zx550.3 Amp (1 sub channel, 2 speaker channels), but my head unit (Pioneer DEH 3300-UB) only has one set of pre amp outputs, and it's a subwoofer output. I don't know too much about head units or multi-channel amps, would it be possible to run this speaker/ sub amp using subwoofer pre-amp outputs?
Thanks for reading.
The rca outs on that unit can be either a fading rear channel out or a non- fading sub out. So yes you can use it, you'd need to switch it to the fading rear out option to be full- range I assume. There is an option to switch in some menu on the HU. Just looked it up on Crutchfield to get that info.
573
482
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
You tried the external relay with no success? If so, how did you wire it?
18
Heads up, those coaxial units I listed above, have a broken tweeter stem. If you go the pioneer route (and at this price, I definitely would) get...
15
C4PT41N3NZ0
C4PT41N3NZ0
Columbus, OH
Fiendstolemyamp
maylar
    Jun 2, 2024
    Jun 1, 2024
