Sundown sa10 or DB machete fight MF-12R
  • 5
I understand now, so with that been said, the DB sub i posted is a good investment to replace the sundown with? If i talk about reliability and built quality.
Sure, 1500 watts RMS and a larger driver are always a good thing, right?
Assuming you are exceeding the output of your amp anyway, you may want to really move it up a notch and do a 15” like this NVX for a substantial increase in output over your existing 10. SAve yourself $50 too! ( needs a 3.5 Cu Ft box, ported, tuned to 31Hz)
https://nvx.com/collections/vc-seri...500w-rms-15-vc-series-v3-dual-2-ohm-subwoofer
I've used this driver in a couple of builds and for the money, hard to beat.
For about $160 more than you are thinking of spending on just that DB driver alone you could get the NVX 15" and a GP glue & srcew ported box tuned to 31hz. I'm sure you could fetch $160.00 for the old setup and then you would really be flexing some glass for roughly the same $$ and alittle extra elbow grease!
For about $160 more than you are thinking of spending on just that DB driver alone you could get the NVX 15" and a GP glue and scew ported box tuned to 31hz. I'm sure you could fetch $160.00 for the old setup and then you wuould really be flexing some glass for roughly the same $$ and alittle extra elbow grease!
Interesting, will think about that for sure.
Thank you guys🙂
605
10
My wife is gonna sh!t bricks when my subs get here. She doesn't know yet
19
idan167
CarAudio.com Recruit
idan167
idan167
maylar
    Jun 2, 2024
    Jun 1, 2024
