Sundown Uv2 12s
Any decent amp rated at 3k-6k rms at the ohm load you are wiring will do just fine. Keep in mind guys will recommend amps much larger due to rise. A 3k at 1 ohm in the real world won’t do 3k. Amps like the taramps smart series will do close to if not rated power as they make the same power at 1-2 ohms. Whatever you choose be sure your electrical system is up to the task.
You stated you have an SIA 3500 right now. I would run it for now with the supply for the demand, until you decide you want more power and have the supply for the demand for it.
I always say.."Run what you got" You can always make upgrades as time and funds are available/budgeted for. Patience usually pays off in the long run
10
My wife is gonna sh!t bricks when my subs get here. She doesn't know yet
19
Is American Bass better then Mmatts? Again I'm in love with quality and smoothness with alot of power and so far I'm Does the ABs have better...
CarAudio.com Regular
Charlotte
audiobaun
audiobaun
    May 19, 2024
    May 19, 2024
