Taramps
AnthonyO
Budget Banger Connoisseur
Which one is better?
DS440x4
LineDS Line
ReferenceDS 440x4
Number of Channels4
Max Output Power12,6 VDC - 2 OHMS: 440W RMS (4 x 110W RMS)
12,6 VDC - 4 OHMS: 276W RMS (4 x 69W RMS)
Signal Noise/Ratio>89dB
Frequency Response8Hz a 26KHz
Input Impedance18K OHM
Protection SystemShort-Circuit
Minimum Supply Voltage8 VDC
Maximum Supply Voltage16 VDC
Idle Consumption800mA
Musical Maximum Consumption23,5A
Sinusoidal Signal Maximum Consumption47A
Dimensions (WxHxD)160 x 44 x 145mm
Weight0,60Kg (1.32lb)
or
TS400x4
Operation ClassClass D
Number of Channels04
Maximum Power
@ 13,8 VDC - 2 OHMS - 400 W RMS (4 x 100W RMS)
@ 13,8 VDC - 4 OHMS - 252 W RMS (4 x 63W RMS)
Bridged @ 13,8 VDC - 4 OHMS - 400W RMS (2 x 200W RMS)
INPUT SENSITIVITY200mV (Vol = max.)
Frequency Response(Full Range): 18 Hz to 30 kHz (-1dB)
Crossover High Pass(HPF)90 Hz (-12dB/8th)
Crossover Low Pass(LPF)90 Hz (-12dB/8th)
Protection SystemThermal and Output Short
Maximum Music Consumption@13,8VDC: 16.5A
Maximum Consumption in Sinusoidal Signal@13,8VDC: 33A
Dimensions(H X W X D)5.43" x 1.93" x 4.76"
Weight1.32lb
The TS400x4 has a little better range and the DS440x4 has a little more output but overall, negligible. They both have fixed x-overs and connectivity is the same.
The ds has more power...it's rated at 12.6v and the ts at 13.8v...
I had the the ts400x4 though and it a good little amp
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
Oh boy do I know too much about that... 20 years as Type 1. :poop:
13
AnthonyO
AnthonyO
Minot, North Dakota, United States
spokey9
maylar
    Jun 2, 2024
    Jun 1, 2024
