Ute-73bt not working with subs
  • 1
keithman2567
I just installed a new ute-73bt. It replaced a cde-133. The amp and sub worked beautifully before switching the head unit. If I connect the amp to the lower, dedicated, sub rca connection I don't get any sound from the sub. If I connect the amp to the upper rcas meant for front and rear speakers I get a signal, but it thumps even with my bass control knob turn all the way down.
Checked the settings
-lpf can't be turned off set to 100
-sub is turned on and raising the level has no effect.
I'll give that try, setting the LPF on the head unit sub outputs to 80Hz and leaving the HPF at 120Hz. If I didn't set an HPF, what would the...
There isn't much it can be. Pull the amp turn on wire out of the amp, and just run a wire from there and touch the distro block will activate...
Its lasted 19 years thus far. Could be something as simple as a wiring connection as stated. Nothing in electronics last forever. Its had a great...
The amp should still turn on regardless of your settings. Those settings will probably cause almost no power to come from the amp, but thats a...
keithman2567
keithman2567
Long Island
keithman2567
maylar
    Jun 2, 2024
    Jun 1, 2024
