Voltage Drop Solvency
  • 4
blade624
Hi, I am having some pretty serious voltage drop in my system. I am dropping from around 14.6v to as low as 10v...the power to my bass is being cut out at these points when it tries to hit hard, or my lights dim. My last set of woofers(MTX roadthunder series) where able to run half the RMS my new Fosgates have, and I really don't feel I am able to push them as hard as a can/want.
I am running a decent(I think) starter battery------http://www.oreillyauto.com/site/c/detail/SSBG/35EXTJ/07053.oap?year=2002&make=Subaru&model=Legacy&vi=5016052&ck=Search_C0423_SSB_5016052_2657&mn=Super+Start&mc=SSB&pt=C0423&ppt=C0005
-I am running a stock alternator running 90 amp.
-I Have done a big three upgrade with 4 gauge wire as well.
-My amp is a 1200 watt(peak)/600RMS@4ohm(1200RMS@2ohm) JBL monoblock.
-2 Rockford P2's 4ohm, wired in parallel for a 2ohm final load(800wRMS combined max)
-micro farad scoche capacitor hooked up. I have a 2 farad vm audio hybrid capacitor on the way too(I know caps are controversial, but it was only 25 bucks)
-3.8 Cubic foot ported box
-My gains and Lpf are set as well as I can without an O scope.
My pocket really only allows me to get one component every paycheck, so I am wondering what I should upgrade first to mitigate voltage drop most efficiently.
I would go with a upgraded Alt- it takes power to make power
second that. a measily 90 amp alt will suffer if thrown an extra big agm in the charging mix. you will more than likely be in the same boat you are in now. caps work but only exceed in certain applications imo.
Are you sure your alternator and battery are both fully functional? This really doesn't sound like what you're running should be too much for factory charging system.
Upgrade just arrived...SHCA Black friday sale for the win. Even more voltage drop, here I come.
18
Thank you all for all the replies, I intend to reply to each and every one individually as I test things out. Here's the latest development that...
13
I was thinking 2 aught wire an do you think it would help if i took the secondary battery ground ran it through the ground sensor an tied the...
blade624
blade624
Coeur d'Alene
hispls
maylar
    Jun 2, 2024
    Jun 1, 2024
