What system should i get for my 2006 Honda Ridgeline?
  • 6
Yes you will get very little help unless you are more specific. you will probably want a sub. That's what I can recommend based on the info given above //content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
There is no "best" of anything... Different subs are good at doing different things. Figure out if you want SQ or SPL or a mixture and how much space you have and how much you're willing to pay...
welcome to the forum btw //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
He wants to be loud he said.
Op, what is your budget and your going to need to work on your electrical also
That box is a prefab POS and a waste of your money. I would go with 2 8's ported you might have enough room for that if not then 2 8's sealed will work. Only you know how much room you have go bust out a tape measure. IDC for shallow mount subs you lose a lot of everything vs a standard sub. YEA gonna NEED a BUDGET
My buget would be 500 to around 800. and i dont want 8's
do you not want 8s becuase you think you wont be loud enough of they wont get low enough?
well your wrong bud //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Here are the reasons of my assumptions and why I think there is little danger in this setup. 1. Bared conductors could cause a spark that leads...
38
4K
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
217
625
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
Heeren
Heeren
Elk point
disturbed471985
maylar
    Jun 2, 2024
    Jun 1, 2024
