Why won't my subwoofer move like it's supposed to?
sammyboi
I've got a Rockford Fosgate P2D4-10, (10" 4ohm 300W RMS DVC) sub wired in parallel to present a 2 ohm load to my amp.
My amp is a soundstream PN5 640D which is 60Wx4 for the speaker channels at 4 ohms, and 350Wx1 @ 2 ohms -- I've wired it to the subwoofer parallel for a 2ohm load.
I'm not expecting it to rattle any windows, I just want a nice sound on the inside. My subwoofer enclosure is made to spec, .64ft^3, but the sub itself does not move like videos of the product do. I've changed LPF and HPF settings hoping to figure it out, the equalizer, and gain.
It moves, but my speakers themselves outdo the subwoofer. I heard you have to break them in, is this why it's not working well? I just installed them after not using that 5th channel, or can I simply not wire the last channel at a different impedance than the main four?
I figured a 350W amp channel would do well with a 300W subwoofer being
How did you set your gains? Where is the sub pointed? In a small sealed box it's best to load the sub off a trunk corner about 6-8" from the corner.
Another option to consider is interconnects. What size wire are you running from the sub to the terminal, terminal to amp, battery to amp? Remember size matters! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
You may also want to consider some poly fiber-fill to eliminate boominess, it'll make things sound tighter/cleaner. Also, how thick is the box material? Anything less than 3/4" can make a difference also.
Lastly, keep in mind that your subs need 300 watts RMS (minimum) and your amp is pushing out 350 watts MAX. So your amp may be struggling a bit while the subs aren't really getting the juice they want. Just a thought.
Where the heck is Mercer Island?
I'm close to Marysville/Smokey Point
An Indian chief named Chief Bowels is being asked to move off a reservation, but refuses. One day he walks into the nearby town and goes into the army hospital, mistaking it for the army headquarters. He goes up to a nurse and says "Bowels no move." So the nurse says, "Here, take this for 2 days, then come back and see me."
So the Indian chief comes back after 2 days and says, "Bowels no move." The nurse says, looking a little disgruntled, "Here, take this for 4 days and come back to see me."
So the Indian chief comes back after 4 days, and before he could say anything, the nurse says, "Let me guess. Bowels no move." The chief says, "No, Bowels move. Bowels have to move, Teepee full of crap."
Pull the head unit out, and at the harness use a test light to check 12v, ground, and Accessory. If all three are good, you have probably...
Is there a BT, USB or other AUX option? May be time to convert your CDs to a solid sate option and use it until you replace the init altogether.
542
Not with a Toyota but with a Dodge Stratus. The Security Key Immobilizer Module (SKIM) was activated and it would not energize the coils. Check if...
Not really, stock car speakers are extremely flimsy from the start and yours are almost 20 years old! I have no trouble believing the bloke who...
882
sammyboi
sammyboi
Knoxville, TN
Rich B
just call me KeV
    Jun 2, 2024
just call me KeV
    Jun 2, 2024
