Will I need a new battery/alternator??
phillipc421
Kansas
Hey guys,
So I will be installing my two Sundown SA-12's running off a Sundown SAZ-2000d into my Jeep Cherokee soon. This is my first build so I am quite the novice, but I was wondering if I will need to upgrade my battery or alternator from stock in order for the system to perform correctly?
Any help is appreciated!
Thanks
Probably, depending on your stock alternator and battery. What is the alt's rated amperage? Stock electrical usually can handle up to around 2k without big issues but depending on the age and strength of the electrical system you will probably need a big AGM under the hood and Big 3. I'd definitely do the Big 3 upgrade, though.
I would run at a bare minimum 180 amp alternator and upgrade your front battery at least.
No not needed. The difference in gain on the amplifier would not draw more power from the battery. Still yet efficient. The gain in volts is a...
505
381
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
418
phillipc421
phillipc421
Kansas
audiolife
maylar
    Jun 2, 2024
    Jun 1, 2024
